Drivers side blend door actuator location
85,000 MILES • V6 • 2WD • AUTOMATIC
BILL JUSTICE
  • 5 POSTS
How to replace drivers side blend door actuator?
Dec 29, 2018 at 7:26 AM
Good evening.
Do you have manual A/C controls or automatic climate control? it does make a difference.
I have attached a picture for you of the automatic climate control since you have dual controls. it is under the left side of the dash on the side of the heater case.
https://www.2carpros.com/articles/replace-blend-door-motor.
If you have manual controls then it is a different story. the dash has to be removed to access the actuator.
The labor for the automatic climate control is .8 hours or about fifty minutes.
The labor for the manual is 6.5 hours.
Dec 29, 2018 at 9:41 AM
BILL JUSTICE
  • 5 POSTS
Thanks for the information. do you know what you have to remove to get to it? thanks, Bill
Dec 30, 2018 at 1:18 AM
BILL JUSTICE
  • 5 POSTS
this is automatic climate control, forgot to mention that.Thanks Bill
Dec 30, 2018 at 1:20 AM
Just the bottom cover under the dash by your feet. it should have a couple of small bolts holding it then you need to get under the dash and up to the side of the heater case.
Dec 30, 2018 at 1:22 AM
BILL JUSTICE
  • 5 POSTS
Thanks a million. getting a little hard moving around in some places at age 69, but still working on them some but mainly on close friends and adult children's vehicles. So I really appreciate the help immensely. Thanks again, Bill
Dec 30, 2018 at 2:03 AM
Glad to help Bill. I am 67 and do not do it anymore. I put in my fifty years and now I teach it.
Happy New Year
Dec 30, 2018 at 2:07 AM
BILL JUSTICE
  • 5 POSTS
Thank again and wishing you and yours a happy -safe and prosperous New Years, Bill
Dec 30, 2018 at 10:05 AM
Thank you. Same to you and yours.
Dec 30, 2018 at 10:30 AM
ANDRE LOUVIERE
I need to replace both actuator's on a 2006 Toyota Sienna, automatic system. Are both sides the same actuator? And do you have a recommendation for what to buy and possibly part numbers? I'd like to go the cheap route so definitely not OEM.
Dec 12, 2019 at 5:42 AM
No, they are different. You can call a parts store and they will give you pricing and part numbers so you can search online for the best deal.
Dec 14, 2019 at 7:48 AM
TSET1963
Is there any difference between 2WD and AWD models? I have a 2013 Limited AWD. I am only getting hot/warm air on Driver side vents.
Gratefully,
Troy Taylor
May 16, 2026 at 7:39 AM
  • 55,588 POSTS
Nope, there is no difference between the AWD and 2WD models for the HVAC system. It sounds like the drivers side blend door actuator is not working.
May 17, 2026 at 8:47 AM
