Car not starting
100 MILES • 3.5L • V6 • AUTOMATIC
SAMMY NEWLIFE
How to replace crankshaft sensor?
Nov 12, 2020 at 4:21 PM
Good morning,
I attached a YouTube video for you on the replacement. All the 3.6 engines are the same for replacing the sensor.
https://www.youtube.com/watch?v=rtR5zvqwOpo
Why do you think it is the sensor? Do you have a code that identifies a sensor issue? When you crank the engine, the tach should move on the dash. If it does, the sensor is working sending a signal to the ECM.
As far as the rest, can you hear the fuel pump run when you turn on the key?
Did you check for spark at the plugs?
Nov 12, 2020 at 9:15 PM
