How to replace camshaft sensor
160,000 MILES
CAROLYN SUE ANDERSON
the car wont start, it turn over but it wont start.
Dec 21, 2018 at 11:53 AM
  • 110,248 POSTS
Are you sure the cam sensor is the problem? The camshaft sensor on this vehicle is difficult to replace. It is behind the timing belt cover. I attached a picture for you to see it. Now, you say the car won't start. The cam sensor won't cause this. If the sensor does not operate correctly, sequential injection is may not occur and the engine may stall or run irregularly at idle or fail to accelerate normally. However, it will run.
With that in mind, read through this link. It discusses the most common causes of a crank no start.
To determine what may be causing it not to start, you should first check to see if there is spark and fuel to the engine.
Once you do that, we will have a better idea what the problem may be. Also, if you have a scanner, check for diagnostic trouble codes. I realize most people don't own one, but often times a parts store will lend or rent one to you. Here is a quick video showing how one is used:
https://youtu.be/YV3TRZwer8k
If you are able to scan the computer, let me know what codes are found. Also, let me know why you suspect the cam sensor.
Take care and I hope something here helps.
Dec 21, 2018 at 12:57 PM
