How to replace the shift cable control system?
200,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
JOEGENT3
Could you help me in replacing my shift cable control assembly system for my vehicle listed above 5-speed manual transmission 1.6 l?
Jan 1, 2025 at 6:00 AM
  • 55,851 POSTS
Sure, here is the overview of the system and how to remove and replace the shift cables, you will need to so some adjustments which I have included for you as well. Check out the images (below). Let us know if you need anything else.
Jan 2, 2025 at 2:56 AM
