How to replace a secondary injection air sensor circuit.
84,500 MILES
MDOLTER
This airflow sensor circuit seems to be down the line from the secondary air pump. Is this correct. I have repaced the secondary air pump. Now I am getting an error code P2432. Secondary AIr injection system incorrect airflow/Sencondary Air Injection system airflow sensor circuit low book. I was told to replace the secondary air injection system air flow sensor.
Thanks Mark
Sep 19, 2013 at 8:12 AM
KHLOW2008
  • 41,812 POSTS
When an error code shows, it does not necessarily mean the sensor is bad. Incorrect air flow could be due to dirt clogging the airpassages and I would suggest cleaning them first. Carb cleaner should help to clear the passages.
Sep 22, 2013 at 12:20 AM
