How to replace a pcv valve on a 2001 buick lasabre.
142,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
PRM1
I want to check & replace the pvc valve on a 2001 buick lasabre. I think the pvc valve is under the MAP sensor but the electrical connection & the MAP sensor do not move easily. Do I need to force them? I do not want to break them.What is the best way to remove & replace the pvc valve?
Thank you,
Phil Morey
phil@pmorey.com
Jun 10, 2014 at 9:46 AM
  • 110,251 POSTS
There should either be a clip that you need to undo or there could be a retainer pin that holds the plug in place. Check for those and let me know what you find.
Jun 10, 2014 at 2:20 PM
PRM1
After opening the clips the sensor or the electrical connection do not come out. Is the pvc valve under the MAP sensor?
Thank you,
Phil Morey
phil@pmorey.com
Jun 12, 2014 at 11:31 AM
  • 110,251 POSTS
I don't recall it being under there. It should be in the corner of the engine.
Jun 12, 2014 at 11:42 AM
