How to replace a headlight lens
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOJO SPARKLE
I need instructions on how to replace a headlight lens on my car. The globes are still working but the glass is broken.
Apr 21, 2018 at 10:02 PM
  • 55,694 POSTS
Yes this is not a big job. Here is a guide to help you see what you are in for when doing the work:
https://www.2carpros.com/articles/headlight-lens-replacement
Please let us know what you find.
Cheers, Ken
May 6, 2018 at 4:58 AM
JOJO SPARKLE
You are the best! Just what I was looking for, thank you very much!
May 6, 2018 at 5:09 AM
STEVE W.
  • 15,409 POSTS
Looking at the information I can find it looks like those are typical composite style lights. For those you replace the entire light unit because they are bonded together. If your light looks like the one in the pictures, it should come out by lifting the hood/bonnet then removing the screws that secure it to the radiator support. Then it should have at least one rubber "socket" that the bottom presses into. After that remove the bulbs and install them into the new housing.
May 6, 2018 at 5:18 AM
JOJO SPARKLE
Thanks Steve, I will make sure that I check that before I start. Cheers!
May 6, 2018 at 5:24 AM
STEVE W.
  • 15,409 POSTS
Just checking to see if you had any luck with your lights?
May 8, 2018 at 2:31 AM
JOJO SPARKLE
Not as yet because I have not been to get the part yet. I will post my progress when I make a start on it. Thanks for checking!
May 8, 2018 at 3:01 AM
