how to replace hvac blend door actuator
80,000 MILES • 2WD
LUNDGREN
Specifically, no air comes out dash or floor vents. If a bump is hit, then the air flow is correct and changeable. AC air is cool and heat air is hot.
Oct 12, 2016 at 7:21 AM
WRENCHTECH
  • 20,758 POSTS
It is not the blend door that you are concerned with. It is the Mode door that you are diagnosing. Here is a diagram of its location. Access may be a problem. https://www.2carpros.com/images/external/105677782.gif
Oct 12, 2016 at 8:46 AM
LUNDGREN
Is the View from Drivers side? I removed the motor on the passenger side through the glove box, it looks similar. but it is not the one.
The motor changed position, how do you change it to match the valve/door?
Oct 12, 2016 at 12:41 PM
LUNDGREN
Thanks, very much for your help.
WRENCHTECH
  • 20,758 POSTS
You do not, it is self calibrating when the battery is disconnected.
Oct 12, 2016 at 12:43 PM
LUNDGREN
When it was disconnected from its shaft, the motor rotated to an impossible to mount position. It is about forty five degrees from being able to fit on the shaft. It must be rotated to be in the rotation range of the door shaft. How to make it turn If I put plus voltage, will it turn and not damage it?
Oct 13, 2016 at 4:41 AM
WRENCHTECH
  • 20,758 POSTS
You should not have turned the key on with the actuator removed. It relies on the door stops to calibrate.
Plug it in and try to change the temperature, but be ready to shut the key off quickly when it gets to the right position. It has to be installed to calibrate.
Oct 13, 2016 at 4:54 AM
