How to remove crankshaft position sensor cable/plug properly?
125,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
YOURMINKY
  • 106 POSTS
The crankshaft position sensor went bad. A friend told me to be extra careful when removing/disconnecting the crankshaft position sensor cable/plug or it will break. How do I remove the crankshaft position sensor cable/plug properly, any videos? Photo attached.
Apr 28, 2021 at 12:49 AM
YOURMINKY
  • 106 POSTS
Photo attached.
Apr 28, 2021 at 12:51 AM
The way to tell how these come apart is to look at the replacement part to determine where they separate. Then if it has a locking tab or clip then they are going to pull off the connector in only one direction. It appears this one pulls off from one of the 2 the larger sides of the connector. I attached a picture below. Please run through this and let us know if you have other questions.
If you can't get it off, put a small flat head under the clip and pry it off and it should pop out as shown by the red arrow on your picture.
Thanks
Apr 29, 2021 at 2:44 AM
