Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mazda
6
Drivetrain
Transmission
Replace/Remove
How to remove clutch/transmission cable clips?
2015 MAZDA 6
114,000 MILES • 4 CYL • 2WD • MANUAL
BHAMDOC1973
MEMBER
You ever replaced or removed these cables? I cannot tell how these clips are holding the cables down.
Image (Click to enlarge)
May 21, 2023 at 8:27 AM
Experienced Mechanic
These are a nightmare. I think they try to make things as confusing as possible.
As far as removal, press the tabs on the control cable and disconnect the control cable from the bracket. See pic below.
Try this and let me know if it helps.
Take care.,
See pic below.
May 21, 2023 at 2:13 PM
Add image or video
Ask a new question
Check engine light
Engine won't start
