I am changing my alternator I am not sure if the diagram is correct for my vehicle and the adjustment bolt on the tension-er pulley will not adjust. should i try to remove the tension-er pulley to loosen the belt and remove the alternator? I have the Passport model.
Feb 12, 2017 at 9:40 PM
