how to install aftermarket fog lights?
2006 KIA SORENTO
151,826 MILES • 3.5L • 6 CYL • 2WD
SEPHOWE
Vehicle only had fog lamp covers so I installed fog lamps and now need to wire them into headlight. do I need to install the fog light switch? if so, how do I accomplish that task?
Nov 16, 2021 at 1:40 PM
  • 110,244 POSTS
The idea that the vehicle wasn't equipped with fog lights changes things. The switch is different in the vehicle as well as the modules. You can't just wire into the headlamps.
Most times when you get new fog lights, it will come with an inline fuse and a toggle switch. That is what I recommend using.
Let me know what you have. Also, take a few pics and upload them so I can see what you are dealing with,
Nov 17, 2021 at 11:51 AM
