Power steering pump installation
174,000 MILES • 2.3L • 4 CYL • TURBO • 2WD • MANUAL
TONY1023
How do you install a power steering pump in the car listed above? It seems easy to do. I rather try myself then pay $741.00.
Apr 5, 2019 at 10:11 AM
  • 110,248 POSTS
Welcome to 2CarPros.
First, here is a link that shows in general how one is replaced:
https://www.2carpros.com/articles/how-to-replace-a-power-steering-pump
Here are the directions specific to your vehicle. You will need to refer to the attached picture for procedure.
_______________________________________________
POWER STEERING OIL PUMP REMOVAL/INSTALLATION [L3 WITH TC]
1. Remove the drive belt.
2. Remove in the order indicated in the table.
3. Install in the reverse order of removal.
Let me know if this helps.
Apr 5, 2019 at 12:33 PM
