How to identify and replace power steering hose
97,500 MILES • V8 • 2WD • AUTOMATIC
CHARLESTUCK
  • 66 POSTS
There is a leak in the power steering hose that goes from the pump over the back side of the engine. When attempting to purchase a replacement, the question is whether it is a pressure hose or return hose.
Nov 27, 2019 at 2:56 AM
Good afternoon,
The pressure line picture is attached with the procedure as well as the return line.
Can you post a picture of the hose leaking?
Change Vehicle Bookmarks Library Request Conversion Calculator Technician's Reference - Collision
Search vehicle information
Community 7 Create Quote
2010 Cadillac DTS V8-4.6L
Power Steering Pressure Pipe/Hose Replacement
Vehicle Steering and Suspension Steering Power Steering Power Steering Line/Hose Service and Repair Removal and Replacement Power Steering Pressure Pipe/Hose Replacement
POWER STEERING PRESSURE PIPE/HOSE REPLACEMENT
Removal Procedure
1. Install a drain pan under the vehicle.
2. Remove the power steering pressure hose from the power steering pump.
3. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle (See: Vehicle Lifting > Procedures > Lifting and Jacking the Vehicle).
4. Remove the power steering gear heat shield. Refer to Steering Gear Heat Shield Replacement (See: Steering Gear > Removal and Replacement > Steering Gear Replacement).
5. Remove the wheelhouse liner. Refer to Front Wheelhouse Liner Replacement (See: Front Fender Liner > Removal and Replacement).
6. Remove the power steering pressure hose bracket retaining nut (2) at the cylinder head.
7. Disconnect the power steering pressure hose (1) from the bracket (2) at the frame.
8. Disconnect the power steering pressure hose from the power steering gear.
9. Remove the power steering pressure hose from the vehicle.
Installation Procedure
1. Position the power steering pressure hose (1) in the vehicle.
2. Connect the power steering pressure hose to the bracket (2) at the frame.
Caution: Refer to Fastener Caution (See: Vehicle > Vehicle Damage Warnings > Fastener Caution).
Return line
Power Steering Return Hose Replacement
Removal Procedure
2. Disconnect the power steering return hose from the power steering pump.
3. Remove the power steering return hose mounting bracket retaining bolt from the cylinder head.
4. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle (See: Vehicle Lifting > Procedures > Lifting and Jacking the Vehicle).
5. Remove the front air deflector. Refer to Front Air Deflector Replacement (See: Air Dam > Removal and Replacement > Front Air Deflector Replacement).
6. Remove the power steering gear heat shield. Refer to Steering Gear Heat Shield Replacement (See: Steering Gear > Removal and Replacement > Steering Gear Replacement).
7. Remove the power steering return hose from wiring harness tie strap.
8. Remove the power steering return hose from the frame brackets.
9. Remove the power steering return hose from the power steering gear.
10. Remove the power steering return hose from the vehicle.
Nov 27, 2019 at 3:53 AM
CHARLESTUCK
  • 66 POSTS
Your diagram is a little different than my car, I believe. I attached a photo.
Nov 27, 2019 at 4:40 AM
It is the same. The hose that shows here is the pressure hose.
Is that the one that is leaking?
Nov 27, 2019 at 5:02 AM
CHARLESTUCK
  • 66 POSTS
Yes. That one goes towards the firewall.The leak is on the underside where the wood is. Are there fasteners behind there and does the hose continue straight down over the valve cover?
Nov 27, 2019 at 5:16 AM
Yes, there are 2 more fasteners between there and the steering rack. The second diagram I sent shows the route of the hose.
The procedure is also attached in a previous post.
Nov 27, 2019 at 5:20 AM
CHARLESTUCK
  • 66 POSTS
What is the orientation of the diagram? Which is front, left or right?
Nov 27, 2019 at 5:29 AM
Number 4 is the left front of the cradle under the car. The picture is the cradle that the engine and transmission is mounted.
Nov 27, 2019 at 5:34 AM
CHARLESTUCK
  • 66 POSTS
Thanks.
Nov 27, 2019 at 7:22 AM
You are welcome.
Always glad to help.
Nov 27, 2019 at 7:28 AM
