How is the front assembly under the steering wheel removed to access HVAC actuators?
124,000 MILES • 4WD • AUTOMATIC
RENOHOPPER
How to gain access to the HVAC Actuators?
Thanks
Jan 7, 2022 at 12:43 AM
SQM
  • 6,383 POSTS
The knee bolster comes out after removing a few bolts.
Which actuator are you having the issue with?
Then blend door or the mode door actuator?
I have attached a few diagrams below showing the procedure.
Jan 7, 2022 at 5:55 AM
RENOHOPPER
Thank you SQM!
I know what the correct term "Knee Bolster"!
I was planning to replace all three. I have a ticking noise that starts when the ignition switch is on and ends when it is turned off. The fan blows what appears to be recirculated air and only through the defrost vent. The other two dials have no effect on the air temperature or circulation.
Thanks for sharing the link to the article.
Thoughts about my approach?
Thanks again!!!
Jan 8, 2022 at 3:34 AM
SQM
  • 6,383 POSTS
You are welcome.
So, the air only blows from the defrost vent right? which will be the mode door actuator.
When you say the other two dial not having any effect on the temperature, do you mean the temperature stays hot or cold regardless of the setting? As that could be the blend door actuator.
Keep in mind that the recirculation actuator is under the dash, and it will require removal of the panel. So, if there is a recirculation issue you might want to keep the other actuator in mind.
Jan 8, 2022 at 4:41 AM
RENOHOPPER
Correct air only blows from the defrost vent.
The air temperature of the air from the defrost vent matches the temperature within the vehicle. It is neither hot or cold.
Jan 10, 2022 at 2:43 AM
SQM
  • 6,383 POSTS
Gotcha. Let me know how it goes after replacement.
Jan 10, 2022 at 3:41 AM
