I am having a problem with getting specific info on gaining access to the ABS module to check wiring and most likely replace just the module.
I started by going through the top, intake components, battery etc. I could probably get the whole unit out, but the pump part is okay, and I just want to get to the module.
There are no videos on remove and replace the ABS module on a Lincoln MKX or a Ford Edge.
Does this procedure require going through the left front wheel area and removal of shroud to gain access? Please advise.
Oct 11, 2022 at 2:45 AM
