how to fix the fans
150,000 MILES
TREYDUCEY
i recently replace my radiator and my thermostat because when my car is in idle or driving it continues to run hot. the only other thing i can think of is the fans cuz i have yet to hear them come on at all. so how do u fix the fans is it a fuse or switch that u replace or the fans itself?
May 13, 2013 at 11:37 PM
HMAC300
  • 48,601 POSTS
you have to see if the relay I sbeing activated to pu the fans on tis could be a temp sensor not working right relay, fuse or fans themselves. if you put your a/con the fans shold work so that would eliminate everything but temp sensor.
May 14, 2013 at 12:28 AM
TREYDUCEY
The fans dont come on even with the ac on
May 14, 2013 at 1:28 AM
HMAC300
  • 48,601 POSTS
then check fuse and relay underhood first. if not that have apro check your temp sensor or run a hot wire to the fans to see if they work to eliminate the motors.
May 14, 2013 at 2:28 AM
