Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Isuzu
Rodeo
Body
Door
Panel
Replace/Remove
How to fix linkage and remove door panel
2004 ISUZU RODEO
200,163 MILES
RACHAEL LEANNE RAMIREZ
MEMBER
1 POST
Both driver and passenger doors will only open from inside. Cannot figure out how to remove door panel so I can check the linkage.
May 23, 2017 at 8:49 AM
Experienced Mechanic
You must remove the door handle first to check the linkage which has probably fallen off of the handle.
Here is a guide that will give you an idea on how to do the job.
https://www.2carpros.com/articles/door-panel-removal
Here is a diagram for your car (BELOW)
Please let us know what happens. I am curious ;)
Cheers, Ken
Image (Click to enlarge)
May 26, 2017 at 8:21 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
