How to fix it O/D
150,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
DEBONILLA
Mi problema es con el piloto del O/D que empeso a enceder sin razon aparente, y desde que se encendio, cuando pongo en marcha el carro aveces se pega como un jalon, por lo demas esta bien, le cambien el aceite la falla desaparecio, pero por solo un dia luego siguio dando la misma falla, me disculopo por escribir en ambos idiomas, pero no escribo muy bien el Ingles, pero talvez hay alguien que si entienda espaol y pueda ayudarlos a traducir.
My problem is with the pilot of O / D empeso to enceder no reason, and since it was lit when I launch the car it sometimes sticks like a milestone, so rest is fine, oil change and lube the disappeared failure but for only one day then followed giving the same fault, I disculopo for writing in both languages, but do not write very well English, but maybe someone who does understand Spanish and can help them translate.
Jan 26, 2015 at 3:08 AM
KHLOW2008
  • 41,812 POSTS
When the O/D light blinks after some driving and gears don't change correctly, it means a fault has been detected in the transmission control system.
You would need a scan to retrieve the trouble code and proceed from there.
I hope I understand your question correctly.
Jan 31, 2015 at 4:18 PM
