Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Highlander
Warning Lights
ABS Light
How to fix ABS light is on and vehicle will not move
2011 TOYOTA HIGHLANDER
172,105 MILES • 6 CYL • 2WD • AUTOMATIC
LUIS SUSANA EDWARD
MEMBER
1 POST
The car will not move. The wheel is stuck.
Jun 24, 2018 at 8:08 AM
Experienced Mechanic
Good evening.
Do you know which wheel?
Were there any symptoms prior to this failure?
It sounds like a brake hose or caliper may be seized not releasing the brakes.
https://www.2carpros.com/articles/brake-caliper-replacement
Jun 24, 2018 at 10:13 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
