How to fix ABS light is on and vehicle will not move
2011 TOYOTA HIGHLANDER
172,105 MILES • 6 CYL • 2WD • AUTOMATIC
LUIS SUSANA EDWARD
The car will not move. The wheel is stuck.
Jun 24, 2018 at 3:08 PM
  • CAR REPAIR CONTRIBUTOR
Good evening.
Do you know which wheel?
Were there any symptoms prior to this failure?
It sounds like a brake hose or caliper may be seized not releasing the brakes.
https://www.2carpros.com/articles/brake-caliper-replacement
Jun 24, 2018 at 5:13 PM
