How to find and replace camshaft position sensor?
50,000 MILES • AUTOMATIC
DBEVIS
engine light came on had checked that was the code.
Sep 29, 2026 at 9:51 AM
  • 55,837 POSTS
Yep, chances are it might not be the sensor, is this the correct mileage? 50k? If not the timing chain might be worn causing the codes FYI, here is a guide to help you understand.
https://2carpros.com/articles/camshaft-position-sensor-symptoms/
Here is the location for the camshaft sensor which there are 2 of, one for the intake and the other for the exhaust for the 2.4 liter.
Oct 1, 2026 at 10:07 AM
