How to diagnose which sensor causing check TOD light?
132,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
DEDE MARKUS
I have come across the similar question in this site and I wonder if I can obtain the diagnostic file as I have no clue on how to retrieve the code.
The car is able to drive. No engine light, just check TOD. I bought a VSS sensor already but I guess it might not be the answer yet.
I am willing to donate for the answer :) Although I am not able to donate too much since I am a student. I can buy you a coffee. A lunch I guess.
Quote:
"An error has been detected in the TOD system and you need to retrieve the trouble code to find out what is wrong."
So I guess I need to know how can I diagnose that as I am not sure whether it is the front right/left or rear left/right. Thanks a lot!
Aug 28, 2018 at 7:55 PM
  • 55,554 POSTS
No need for a donation we just want to get to a conclusion is all we ask. The " Torque On Demand" light is telling you reduced power or limp mode. Lets run the codes to see what is going on you can get a code reader from Amazon for $20.00. Here is a guide to help us get started:
Cheers, Ken
Aug 30, 2018 at 3:53 AM
DEDE MARKUS
Hi Ken, I do have a OBD2 reader but it is not able to retrieve the code. I bought that to a mechanic, he said the code can only be read by the dealership as it is not engine light but the TOD light.
Aug 31, 2018 at 7:08 PM
  • 55,554 POSTS
These lights are kind of the same thing both tell you there is a malfunction. Does the code reader not connect or is there no codes?
Sep 1, 2018 at 4:10 AM
DEDE MARKUS
There are no codes. Just the Check Tod light keeps flashing, no codes can be read by the reader.
Sep 1, 2018 at 8:42 AM
  • 55,554 POSTS
It sounds like the throttle pedal sensor and the throttle body have lost their correlation. Disconnect the battery and remove the throttle body for service. This guide will show you how:
Cheers, Ken
Sep 3, 2018 at 5:24 AM
