How to detect EVAP system leak with smoke tester?
85,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
XJSHEN
  • 251 POSTS
There was a EVAP system leak test failed by by DTC's diagnosis. I got smoke tester. But I don’t know where to connect the smoke delivery tube tip.
Thanks for your instruction and helps!
Nov 21, 2020 at 6:01 AM
  • 110,248 POSTS
The EVAP service port is located in the EVAP purge pipe between the EVAP purge solenoid and the EVAP canister. The service port is identified by a green-colored cap
I attached two pics below. The first shows the canister which is near the fuel tank. The second shows the solenoid. If I recall, the service port is near the purge solenoid (number 11 in pic 2)
Let me know if this helps.
Joe.
Nov 21, 2020 at 11:55 AM
