How to check oil level ATF?
20,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
PAWEL_N
  • 178 POSTS
Could you please tell me how to check oil level ATF - 8 speed? I am not sure if there is the right level. Thank you.
Jul 24, 2022 at 6:00 PM
  • 55,732 POSTS
There is a drain plug in the side of the transmission, so it fills much like a standard transmission. Here is the additional info the manual gives us:
The 8HP has a conventional fluid sump design and the filter is serviced separately from the oil pan. The oil pan gasket is reusable providing it is not damaged during removal. Oil dye is not required to find leaks in the 8HP transmission. The oil dye can cause shift quality issues and is not recommended. The fluid has illuminance that is visible under a black light.
STANDARD PROCEDURE - CHECK OIL LEVEL
To properly check and fill the transmission, perform the following procedure:
WARNING:
There is a risk of accident from vehicle moving when the engine is running. Secure vehicle to prevent it from moving. There is a risk of injury from contusions and burns if you insert your hands into the engine when it is running. Do not touch hot or rotating parts. Wear properly fitted work clothes.
CAUTION:
A unique transmission fluid has been developed for this transmission. This fluid is NOT compatible with ATF+4 or any other current Chrysler transmission fluid. For specifics about this unique fluid see FLUIDS, LUBRICANTS AND GENUINE PARTS .
NOTE: Oil dye is not required to find leaks in the 8HP transmission. The oil dye can cause shift quality issues and is not recommended. The 8HP fluid has illuminance that is visible under a black light.
Raise and support the vehicle on a level hoist (Refer to 04 - Vehicle Quick Reference/Hoisting - Standard Procedure) .
Start the engine. The engine must continue to run for the entire test.
Using a scan tool or the vehicle information center, verify that the transmission fluid temperature is between 30°C (86°F) and 50°C (122°F).
Disable traction control (ESC).
Remove the fill plug from the right rear of the transmission case.
Add transmission fluid until it trickles from the fill opening.
Install the fill plug.
Lower the vehicle for access to inside of the vehicle, leaving the tires at least 8 inches off the ground.
With the brakes applied, place the transmission in Reverse and hold for 5 seconds.
Place the transmission in Drive and hold for 5 seconds.
Release the brakes, slowly accelerate to 2nd gear and hold for 5 seconds.
Apply the brakes and place the transmission in Neutral.
Raise the engine speed to 2000 RPM for 5 seconds.
Return the engine to idle and place the transmission in Park.
NOTE:
A full transmission will have fluid at the fill hole with the transmission between 30°C (86°F) and 50°C (122°F). Do not over fill.
Remove the fill plug and allow excess fluid to drain from fill hole or add fluid as necessary.
Using a scan tool, clear any DTCs.
STANDARD PROCEDURE - TRANSMISSION FILL AFTER SERVICE
CAUTION:
A unique transmission fluid has been developed for this transmission. This fluid is NOT compatible with ATF+4 or any other current FCA US LLC transmission fluid. For specifics about this unique fluid see FLUIDS, LUBRICANTS AND GENUINE PARTS .
To properly fill the transmission after an in vehicle service or overhaul, perform the following procedure:
NOTE:
If the transmission cooler was replaced, add an additional 0.7L (0.72 qts) of transmission fluid.
If the transmission was overhauled, prior to installing in the vehicle, tip the transmission on it side, remove the oil fill plug on the right rear side of the case and install 9L (9.5 qts) of transmission fluid. Install the fill plug. After installing the transmission, perform the CHECK OIL LEVEL procedure (Refer to 21 - Transmission and Transfer Case/Automatic - 8HP70/FLUID and FILTER/Standard Procedure) .
If an in vehicle service was performed, raise and support the vehicle (Refer to 04 - Vehicle Quick Reference/Hoisting - Standard Procedure) , and perform the CHECK OIL LEVEL procedure (Refer to 21 - Transmission and Transfer Case/Automatic - 8HP70/FLUID and FILTER/Standard Procedure) .
Jul 25, 2022 at 5:24 AM
PAWEL_N
  • 178 POSTS
Thank you for your help. :-)
Jul 25, 2022 at 6:50 PM
  • 55,732 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Jul 27, 2022 at 5:12 AM
