How to change valve cover gasket?
2013 BMW 550I
115,000 MILES • V8 • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
Any instructions?
Apr 10, 2023 at 3:32 AM
BHAMDOC1973
  • 2,007 POSTS
Also, is there something that can leak in back of the valve cover, as i see something dripping, maybe a vacuum pump seal?
Apr 10, 2023 at 4:27 AM
  • 110,241 POSTS
Does the leak behind the cover appear to be engine oil? A vacuum pump wouldn't cause this to happen.
As far as replacing the valve cover gaskets (cylinder head cover gaskets) I attached the directions below. Note: The first four pics are related to the left side and the last pics are the right side.
The directions are vague and provide preliminary steps prior to the covers. I'm not sure what you are comfortable with, but if there is something specific you need in the list, let me know and I'll get it for you.
take care,
Apr 10, 2023 at 2:13 PM
BHAMDOC1973
  • 2,007 POSTS
I thought the 3 series BMWs and some of the Benz have a pump in back that has a seal that usually leaks, not sure. I started the job on this one, OMG, how many coolant hoses does it take to make this car? a billion? I am having issues getting the fan out, everything on top has to come out which isn't an issue just time consuming.
Apr 12, 2023 at 7:12 AM
  • 110,241 POSTS
I totally understand the idea of time consumption. As far as the coolant hoses are concerned, it is unbelievable. I had an Audi A8 and the alternator was liquid cooled. Ugh! What will they do next?
Take care and let me know if I can help.
Apr 12, 2023 at 12:30 PM
BHAMDOC1973
  • 2,007 POSTS
Oh, yes, seen those cooled alternators, a pita.
Apr 12, 2023 at 12:34 PM
