how to change the shift interlock cable
56,000 MILES • 6 CYL • 2WD • AUTOMATIC
TOM GROSE
The floor console shift lever will not shift out of park.
Jan 9, 2020 at 2:05 AM
Good afternoon,
I attached the procedure for removing the cable to the shifter. By disconnecting the end, you will be able to move it out of park.
I attached both the floor shift as well as the column shift as well.
Jan 9, 2020 at 2:46 AM
TOM GROSE
Thank You for your help!
Tom
Jan 9, 2020 at 2:54 AM
You are welcome.
Always glad to help.
Jan 9, 2020 at 2:58 AM
