How to change the fuel pump/filter
200 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
ASKED QUEST
Van starts .but dies stay running. When you try to accilerate for more gas.
Oct 26, 2014 at 5:14 AM
JDL
  • 16,098 POSTS
I'd use a gage and check fuel pressure before you go after the fuel pump. My info says 48 psi. The fuel filter is a tune-up part, should be located along the chassis underneath. You may have to safely raise and support the vehicle to get at the filter.
My info says you have to drop the gas tank to get at the fuel pump.
Oct 26, 2014 at 6:08 AM
