fuel injector replacement?
1,571,625 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
LARHAR
Misfire on number 1 cylinder. I need to change the injectors.
Dec 21, 2015 at 9:27 AM
If you have a misfire on one cylinder, I would swap the injector to another cylinder first just to make sure it is the injector. The misfire should move to the cylinder with that injector.
I attached the process for replacing the injectors. Let us know what questions you have.
Here is also a guide that will help:
Thanks
Nov 27, 2020 at 12:42 PM
