How to bypass anti-theft in the ignition switch
200 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
TIM ROBERTDON
I am getting the car to crank, but it will not stay running.
Mar 12, 2016 at 1:55 AM
TIM ROBERTDON
I have heard of ohming out two wires getting the resistance reading and connecting a resister between the wires then it will stay running..not sure if this can be done on this car?
Mar 12, 2016 at 2:09 AM
HMAC300
  • 48,601 POSTS
try resetting security system if no manual look online for your vehicle how to reset
Mar 12, 2016 at 2:22 AM
HMAC300
  • 48,601 POSTS
The newer cars cannot be bypassed.
TIM ROBERTDON
So if it cannot be bypassed is the only option is to take it to a Honda mechanic?
Mar 12, 2016 at 2:39 AM
HMAC300
  • 48,601 POSTS
No try to reset it first especially if you replaced the battery or if it was dead then charged. look online for your car. any mechanic with a pro scanner can check it to see what is wrong.
Mar 12, 2016 at 3:46 AM
TIM ROBERTDON
I know what is wrong. I am trying to figure out how to bypass the anti-theft in the ignition switch. I am getting it started, but it will not stay running due to wiring in the switch needs jumped out. I do not know which wires it is.
Mar 12, 2016 at 3:58 AM
HMAC300
  • 48,601 POSTS
good luck
Mar 12, 2016 at 5:25 AM
