Car running hot and I need to bleed the cooling system.
Aug 23, 2016 at 11:31 PM
HMAC300
✓Experienced Mechanic
have coolant system pressure checked for an internal leak unless tank is full then get hot check radiator for cold spots if any then the radiator is bad.
Aug 23, 2016 at 11:38 PM
HMAC300
see picture for bleeding system, but I do not think this is the problem .
