Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Acura
CL
Engine Cooling
Air Bleed Valve
how to bleed old antifreeze?
1997 ACURA CL
145,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
KTIEDE
MEMBER
cannot locate the bleeder bolt to bleed anti-freeze.
Oct 28, 2021 at 3:43 AM
SQM
Experienced Mechanic
The bleed bolt is located rear side of the cylinder block. I have attached the procedure below.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Images (Click to enlarge)
Oct 28, 2021 at 4:25 AM
KTIEDE
MEMBER
Thank you much.
Oct 28, 2021 at 5:09 AM
SQM
You are welcome.
Oct 28, 2021 at 5:39 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
