I just replaced the master cylinder and my brakes still feel squishy. How do i bleed the brakes so my car can stop?
Dec 18, 2016 at 6:58 AM
HMAC300
CERTIFIED EXPERT
you probably have air in the ABS unit. you can try a power bleeder otherwise a mechanic will need to hook his scanner up to bleed the system so he can open valves on ABS to bleed it.
Dec 18, 2016 at 8:25 AM
STEVE W.
CERTIFIED EXPERT
Did you bench bleed the master cylinder before installing it? Why did you replace it? Does it have ABS?
