How to add oil to the transmission?
YANNICRISANTOS
  • 1989 TOYOTA CAMRY
  • 2,000,000 MILES
Well I changed the Axle and a lot of oil came out and I wanted to see how could I add more oil to the transmission? And if it's possible to show me a diagram and tell where is at because I can't find it.
Saturday, June 29th, 2013 AT 12:33 PM
YANNICRISANTOS
  • 132 POSTS
Is a manual trans
Saturday, June 29th, 2013 AT 12:40 PM
KHLOW2008
  • 41,814 POSTS
There is a fill plug somewhere along the center line of the transmission. Check for a 19 or 24 mm hex bolt along the center line of the trransmisison. Remove it and fill transmission oil till it flows out.
If 4WD, the filler plug would be hidden by the sub frame, at rear of transaxle.
Sunday, June 30th, 2013 AT 3:11 AM
