How to activate hidden option in the radio?
25,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
PAWEL_N
  • 178 POSTS
I read that it is possible to change radio frequency from USA (the last number only 1-3-5-7-9) to EU country (all numbers 0-1-2-3-4-...) and activate other language (Polish) in radio. It is possible in Durango 2019-2021. It is not possible in cars from 2014 years.
Do you know how to do it??? How to activate the hidden options in the radio menu?
I am waiting for your reply.
Have a nice day,
Pawel
Frequency and language for EU country.
Apr 6, 2022 at 8:27 PM
The only way that I know to change the languages on the vehicle is to use a scan tool that is capable of changing the country code.
Basically, you go into the BCM and there is a drop-down menu that allows you to select the country you would like, and it changes the language to that country.
As for unlocking hidden items. I have heard that there are tools out there that can do it but there is not a trick that you can do in order to get them unlocked. You would need to find and purchase a tool that can turn on the NAV and other functions that may not be equipped on this vehicle.
The only actual way to do this is to purchase the functions from a dealer and they will add the sales codes and then reset the BCM which will turn these on. However, there are not many functions that you can do this with.
Hopefully this helps.
Apr 7, 2022 at 10:01 AM
PAWEL_N
  • 178 POSTS
Thank you for your reply. I will go to the man with scan tool and ask for it. I will give you feedback as it looked.
Thanks.
Apr 7, 2022 at 6:02 PM
Thanks. Sounds good. Thanks for the update. We will wait to hear back.
Apr 8, 2022 at 5:40 AM
