I can't find any info on how tight to torque the Adjusting Nut that holds the front rotor and hub assembly to the spindle on my vehicle listed above.
I see posts from anywhere between 130 and 190 ft. lbs., but anything over 30ish and the wheel won't turn freely.
I find at 25 ft. lbs., it holds the rotor on nicely with no play and can still rotate rather wheel but does not spin freely.
Feb 4, 2023 at 8:20 AM
