How radiator fans and thermostat works
OGUNLEYE
  • 1997 TOYOTA CAMRY
  • 2.2L
  • 4 CYL
  • 26,000 MILES
After the radiator fans have turn on when the engine has reached the normal temperature. How is the radiator fans suppose to work after turn on?
Tuesday, October 15th, 2019 AT 6:54 AM
  • 109,896 POSTS
Welcome to 2CarPros.
Here are two links to help answer your questions. Take a look through them and let me know if they help.
https://www.2carpros.com/articles/how-an-engine-thermostat-works
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
Tuesday, October 15th, 2019 AT 7:10 PM
OGUNLEYE
Yes it help.
Thursday, October 17th, 2019 AT 5:14 AM
OGUNLEYE
It help but my car radiator fans don't off and on after turn up. Is there any problem with that.
Thursday, October 17th, 2019 AT 5:19 AM
  • 109,896 POSTS
Not sure I understand. Are the fans staying on after the key is turned off? If that is the case, I would check to see if there is an issue with one of the relays.
Thursday, October 17th, 2019 AT 6:53 PM
