How much would it be to replace water pump in this vehicle
89,273 MILES
PANDABEAR630
Replaced thermostat and flushed radiator it is still not blowing hot air when it is idling
Oct 10, 2019 at 7:57 AM
Good evening,
I doubt it will be the water pump at all. From your post, it sounds like it could be a clogged heater core. Removing both lines and flushing with a garden hose usually takes care of this.
https://www.2carpros.com/articles/car-heater-not-working
As far as the price for a pump, you would be looking at around 300-450 depending on the motor you have in the car.
Oct 10, 2019 at 8:48 AM
PANDABEAR630
Thank you Roy, exactly what my mechanic said when I contacted him about the problem.
Oct 13, 2019 at 2:00 PM
You are welcome.
Always glad to help.
Oct 13, 2019 at 8:35 PM
