How much transmission fluid do i need to put in?
169,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
BLAKR
So, i wasn’t paying attention and accidentally pulled my transmission plug instead of my oil plug and let it drain until it was only slightly dripping, i did put the old fluid in an old jug and it was about 3/4ths full.
Jul 28, 2023 at 8:01 PM
  • 55,658 POSTS
It will usually take about 4 to 5 quarts. This video will help:
https://youtu.be/OSRkzuX20o8
Fluid Types
NOTE: MERCON Automatic Transmission Fluid is being replaced by MERCON V as a service fluid.
Automatic (4R70W) .................... MERCON V ATF
Automatic (4R100) .................... MERCON OR MERCON V ATF
NOTE: Automatic transmissions requiring MERCON V should only be serviced with MERCON V, or fluid from container that is specified as a dual usage fluid: MERCON/MERCON V.
NOTE: Automatic transmissions requiring MERCON can now be serviced with MERCON, MERCON V, or dual usage fluids labeled MERCON/MERCON V.
Capacities
A/T Fluid
4R100 .................... 15L (15.9 Qt)
4R70W .................... 13.1L (13.8 Qt)
NOTE: Approximate dry fill capacity. Fluid level should be set by indicator on dipstick's normal operating range.
Jul 29, 2023 at 6:55 AM
