How many catalytic converters are there?
135,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
SSHOUPP
Need to replace but need a number to buy.
Feb 28, 2022 at 8:59 AM
  • 110,251 POSTS
According to my manual, this vehicle only has one. It should be located approximately in the center under the vehicle. I attached a pic below showing it.
Here is a link you may find helpful. It explains in general how one is replaced.
I hope this helps. Let me know if you have other questions. Also, when you get the new converter, there is likely a flange gasket between it and the flex pipe, so make sure to get one.
See pic below.
Feb 28, 2022 at 11:12 AM
