I want to know specifically if my car has 2 or 4 catalytic converters.
Dec 30, 2019 at 12:55 PM
JIS001
✓Experienced Mechanic
It looks like you have 2 but the emissions label will tell you for sure. See images below. The emissions label I attached is an example. If you take a picture of it I can tell you for sure how many you have.
Images (Click to enlarge)
Apr 13, 2021 at 3:38 AM
STEVE W.
If it's the base model 3.7 it has 2 converters, one for each cylinder bank, then a set of resonators behind them. Then there is the crossover. Then the rear section of the system with dual mufflers.
LEBEAUTIFUL JAMES
MEMBER
So if I change the exhaust midpipes and keep my stock catalytic converter, will I still pass the smog check in California?
JIS001
As long as the stock catalytic converter is there you should be good.
