how long does it take to change a knock sensor on a infiniti j30
2WD • AUTOMATIC
MICHAEL ROBINSON
code indicates this is the problem
Mar 29, 2014 at 12:51 AM
WRENCHTECH
  • 20,758 POSTS
No, the code doesn't indicate that is the problem. The code indicates there is an issue somewhere in the circuit which could be the sensor itself, the computer or any related wiring although the odds are good it's the sensor. It's quite a job on those because the intake manifold has to be removed to access it.
Mar 29, 2014 at 3:44 AM
