Code p0502 speedometer stays at 0?
13,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
FRANCISCOSANDOVAL
I have a flashing D light. Code p0502 speedometer stays at 0 speed?
Oct 25, 2022 at 1:42 AM
  • 55,732 POSTS
The code P0502 is a difference in speed reading between the vehicle speed sensor (VSS) and the wheel speed sensors. I would install a new VSS sensor to fix the problem here is the location so you can do the repair and clear the codes. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Oct 25, 2022 at 5:28 AM
FRANCISCOSANDOVAL
What is the part number ?
Oct 26, 2022 at 10:37 PM
  • 55,732 POSTS
They don't show it, but I found the part.
Here are the parts on Amazon:
https://amzn.to/3FnvI5K
Let us know what happens and please upload pictures or videos of the problem.
Oct 27, 2022 at 4:06 AM
