how hard or easy it is to change power steering pump and pulley
1998 FORD ESCORT
89,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
TNCUB47
power steering pump moves back and forth where pully shaft is at and power steering fluid is brown and smells burnt
May 4, 2014 at 2:17 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
you need a special puller for the pulley to remove and replace it. you have to take a bunch of stuff off an dneed the pullers to replace the pump you can rent a manul here for a week to have that at your disposal. the pulley is one of the first things that have to be removed.
May 4, 2014 at 4:04 PM
