Codes P106,P0410,P0171, P0304, P0303,P0300,P0730P, P0174P
303,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
ERIC92866
OBD codes P106,P0410,P0171, P0304, P0303,P0300,P0730P, P0174P. Exhaust rattle, reduced power.
Jun 24, 2017 at 1:47 PM
  • 55,561 POSTS
It sound like the catalytic converter has fallen apart and it blocking the exhaust from exiting the engine which will explain the reduced power. Here is a guide the can help you get the problem fixed.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
and if it is bad here is a guide that will show you what you are if for when replacing the unit.
https://www.2carpros.com/articles/catalytic-converter-replacement
Once the repair have been done clear the codes to recheck
https://www.2carpros.com/articles/check-engine-light-clear-codes
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Jun 27, 2017 at 4:49 AM
