how exactly do i get to the spark plugs and wires?
148,000 MILES • 4 CYL • FWD • AUTOMATIC
GIMMEDAT
rough idle while stopped
Jul 22, 2014 at 9:49 AM
FREEMBA
  • 1,152 POSTS
2.4L Engine
Specific to:
Toyota Camry 2007-2008
Before servicing the vehicle, refer to the Precautions Section.
Remove the plastic engine cover.
Disconnect the 4 ignition coil connectors and remove the 4 bolts and ignition coils.
Using a 16 mm (0.63 in.) Spark plug wrench, remove the 4 spark plugs.
Installation is the reverse of removal.
Torque the ignition coils to 66 inch lbs. (7.5 Nm) and the spark plugs to 13 ft. lbs (18 Nm).
Jul 22, 2014 at 11:09 AM
FREEMBA
  • 1,152 POSTS
Try cleaning the throttle body using carb/throttle body spray cleaner, a rag and/or small soft bristle brush.
Jul 22, 2014 at 11:12 AM
