How do you test the oil pressure sender/switch
1989 BUICK REGAL
56,100 MILES • 2.8L • V6 • 2WD • AUTOMATIC
COOLOLDS85
  • 173 POSTS
My oil pressure sender/switch is located near the oil filter with three wires. What is the accurate reading you need to get for the sensor to still be in good working condition? Is there any information on how to look if it is good?
Sep 27, 2018 at 4:31 AM
Good afternoon.
You would need a voltmeter to monitor the sensor or signal wire back to the dash unit.
I attached the description below.
This oil pressure indicating system incorporates an instrument voltage regulator, electrical oil pressure gauge and a sending unit which are connected in series. The sending unit consists of a diaphragm, contact and a variable resistor. As oil pressure increases or decreases, the diaphragm actuated the contact on the variable resistor, in turn controlling current flow through the gauge. When oil pressure is low, the resistance of the variable resistor is high, restricting current flow to the gauge, in turn indicating low oil pressure. As oil pressure increases, the resistance of the variable resistor is lowered, permitting an increased current flow to the gauge, resulting in an increased gauge reading.
Sep 27, 2018 at 4:51 AM
COOLOLDS85
  • 173 POSTS
I understand what it does, just wondering what to set the volt meter to? Ohms or volts? And what reading does it need to be? Does the car need to be running or can I do KOEO to key on accessory to monitor what the sensor is doing? And trying to understand the characteristics, if oil pressure increases, does that means the sensor is is monitoring and working?
Sep 27, 2018 at 6:17 AM
You need to monitor the signal wire at the sensor with the engine running. The voltage will be low without the engine running and that reading will be low. When the voltage raises it sends a signal to the dash the gauge will rise.
They do not give voltage vs gauge reading specs.
You will have a 5 volt reference voltage, a ground and a signal return wire on the connector. The voltage on the signal wire will vary between 0 and 5 volts.
Sep 27, 2018 at 6:33 AM
COOLOLDS85
  • 173 POSTS
Okay, I will let you know what I find, but if the sensor is not in that range, does that mean there is a problem and it needs to be replaced correct?
Sep 27, 2018 at 7:06 AM
That is correct.
Sep 27, 2018 at 7:15 AM
COOLOLDS85
  • 173 POSTS
May I have a diagram to know which wires are which? So I know I get the correct reading.
Oct 19, 2018 at 12:23 AM
I cannot find a diagram of the connector but it is the tan wire that is the signal wire.
back probe the wire with the engine off and then with it running, there should be a change in voltage. 5 volts is sent to the sender unit.
Oct 19, 2018 at 8:18 AM
COOLOLDS85
  • 173 POSTS
You are right. I checked and voltage was changing, if it did not change it would not have pressure.
Oct 19, 2018 at 12:12 PM
That is correct.
I would replace the sensor.
Oct 19, 2018 at 9:33 PM
COOLOLDS85
  • 173 POSTS
Is the sensor is working fine? I got 5 volts than readings were going all over the place. Does that mean it is bad if it does not stay steady at 5 volts? You mentioned there should be a change in voltage from 5 volts. It did change from 5 volts and sensor kept changing when engine was running.
Oct 20, 2018 at 6:06 AM
It should go from 0 to 5 volts very smoothly. If it is all over the place, then the cluster gets confused on that voltage and does not know what to set for a reading.
Oct 20, 2018 at 7:22 AM
