how do you remove the wires from the coil
6 CYL • 4WD • MANUAL
WHSCOOKIII
trying to remove the wires from the coil of f-150 6 cylinder pick up truck
Oct 11, 2014 at 12:07 PM
CJ MEDEVAC II
  • 222 POSTS
I HAVE 2 JEEPS, MY 1977 AMC CJ-5 HAS MOTORCRAFT IGNITION (FORD)
IF YOURS LOOKS LIKE MINE IN THE PIC BELOW, IT'S A HALF MOON CONNECTOR THAT SNAPS ONTO THE COILS RIM
GRAB IT ON EITHER SIDE AND SORTA "WORK"/ GENTLY PULL THE FRONT SIDE THEN THE BACK SIDE A LITTLE AT A TIME AND IT WILL SNAP OFF OF THE COIL
A QUICK JERK OF ONLY ONE OF THE SIDES MAY BREAK IT IN HALF
LEMME KNOW HOW IT GOES
THE MEDIC
Oct 11, 2014 at 12:49 PM
CJ MEDEVAC II
  • 222 POSTS
DID I MISUNDERSTAND?
ARE YOU TRYING TO REMOVE THE WIRES FROM THE CONNECTOR (NOT THE COIL)?
THE MEDIC
Oct 11, 2014 at 1:24 PM
MAXIMILIAM
  • 436 POSTS
No, I am trying to remove the wires from the coil. It has a plastic case which I do not want to break.
Regards,
whscookiii
Oct 13, 2014 at 11:31 PM
CJ MEDEVAC II
  • 222 POSTS
SO LIKE WERE YOU ABLE TO REMOVE IT VIA MY 1ST RESPONSE?
THE MEDIC
Oct 14, 2014 at 8:45 AM
