we know how to remove the actual socket but do we need to break the bulb or change the entire assembly?
Dec 12, 2019 at 7:36 AM
STEVE W.
✓Experienced Mechanic
Looks like it takes a 168 peanut bulb. The assembly comes out and uses 1/4 turn locking to secure the socket to the lens. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Image (Click to enlarge)
Dec 12, 2019 at 7:44 AM
SET1421
MEMBER
1 POST
2005 Toyota Sienna
How do you replace the tag light bulbs?
Oct 19, 2020 at 10:08 AM
(Merged)
ZACKMAN
Remove license plate lamp assembly
a. Release the 2 claw fittings and disconnect the license plate lamp assembly
b. Disconnect the connector and remove the license plate lamp assembly
c. Pull the lamp straight out.
(Merged)
GGMORE
MEMBER
1 POST
Electrical problem
2004 Toyota Sienna 6 cyl Front Wheel Drive Automatic
i need to change 1 of the 2 license plate lights but don't see any entry.I'm assuming I might have to take off the whole interior panel of the lift door but I'n not sure and not sure how to do it???
HELPPPPPPPP
(Merged)
BLUELIGHTNIN6
The back door interior panels are held in with special clips. To disengage these clips you must first purchase a clip remover. Then simply disengage the clips to remove the panels. Then remove the back door pull strap and trim board assembly. Remove teh sub-assembly outside panel and then you can remove teh license plate lamp assembly. Do this by releasing the 2 claw fittings and disconnecting the license plate lamp assembly.
