how do you change transmission fluid
82,000 MILES • 2.3L • V8 • AUTOMATIC
MARIA VINEY
where is plug located and how do you refill?
Aug 3, 2016 at 11:47 PM
HMAC300
  • 48,601 POSTS
there is no plug for drainage only one to refill which must be done on level ground or a hoist. the pan must be pulled to drain old fluid. if you have the ZF5hp transmission there is a filler plug at right rear of transmission. if a hydramatic it goes through the filler tube. THis guide will help walk you through the job
Check out the diagrams (Below). Please let us know what you find.
Aug 4, 2016 at 2:39 AM
